sk8ersublime
A monitor by itself will power up without a game attached, but you might not see anything on the screen if the brightness is properly set. You should see the heater element in the tube's neck glow, and if you adjust the brightness all the way up, you should see a raster pattern on the monitor.
An isolation transformer is not required for a monitor plugged in by itself (without a game), simply to see if it works. However, risk of shock is increased, and you should never use a monitor without an isolation transformer with a game or with any test equipment!
Any ideas why mine would not? I replaced all of the caps with the DK jr. Plus kit from Arcadeshop.com There was one that i noticed was different than the old one tho.
the old one was "33uf @ 160V" they had me replace it with "100uf @ 160V" would a cap or maybe a broken trace to a cap cause this thing not to fire up? I mean, i would expect if the cap was wrong or a bad trace, there would be some smoke or something.
