You have "x" seconds to hit the center drop target and then the arrow advances. Then "x" seconds to hit it again and so on. If your center target is dropping by itself or not resetting that could be causing the timer to fire on its own.
Yeah I'm Todd's video after X seconds the target goes down by itself. On mine it only goes down if I hit it. Otherwise it's up all the time.You have "x" seconds to hit the center drop target and then the arrow advances. Then "x" seconds to hit it again and so on. If your center target is dropping by itself or not resetting that could be causing the timer to fire on its own.
Yeah in pretty sure of that too, it's probably the wiring.In the solenoid test, does the knock down solenoid work on the center target?
You have three small solenoids on top of the target bank that are hard to access. One drops the left target, the center, and the right target.
Edit: I watched the video around the 1:49 mark and the center target is dropping on the timer correctly. It looks like you hit the center target but the arrows never advanced (as the arrows advance you have less time to hit the target). With the longer wait to drop the target, its hard to notice and it wont even happen if you drain quickly. The arrows did light in the lamp test though, so I bet your center drop target switch is not working.
Finally got to putting a video together, it's 2 1/2 hours long!
https://www.youtube.com/watch?v=jeI8v2qMa2M
Awesome! Thanks!Nice! I have my tv watching chosen for tonight. I love these videos.
