Just bought Tapatalk for Android & can't login
Same here and never had a problem with my Android phone. I'll have to check this out and see what improvements it offers.
I just got the Optimus V, which s very nice, but the resolution sideways is 480x320. You might have a phone with a 800 pixel + width display.
I just turn the phone sideways and can read the threads just fine on my phone.:confused:
If you have x-ray vision. :rolleyes: What phone do you have? I have an iPhone 4 and if I turn it sideways and squint I can barely read it... and I end up with a headache for my troubles within 5 minutes. This (Tapatalk) is great (if it works for you).
I'm using the Droid X which has a larger screen than most which helps.
Yah it does! Your screen:
854x480
My screen:
480x320
I have a droid 2 and I just have to tap the screen once and it zooms in and I can read it easily.
I only have to scroll side to side on posts that have really long sentences.
Most pages fill the screen when sideways.
If I had the X then I probably wouldn't have to scroll at all but I didn't want a phone that big.
You should be able to do the same or just use the pinch zoom on the iphone.
Testing from my Iphone. So far so good, a much nicer way to browse the forums from my phone.
wont let me log in which is weird cause it even changed my username (with capitals and such)
I use this for like 3 other forums with no problems
I don't think it works for any android user obviously there is something wrong with how it is setup on th server. Pm Mclemore and let him know it Isn't working for android clients.
I got an answer from Tapatalk
Looks like the issue is with how the forums are configured:
http://tapa.tk/forum/showthread.php?t=5305
Hi Tighe,
The issue since your server require a special http header "Accept: */*" in http request . We will add this header in coming android version.
You can wait next android update for fix or you can change your server setting to remove the must requirement of "Accept" http field.
All Engrish aside, I wonder when the next version comes out. I hope they can make the change here.Here are the request header I get from the forums:
Code:
GET / HTTP/1.1
Host: forums.arcade-museum.com
Connection: close
User-Agent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X; de-de) AppleWebKit/523.10.3 (KHTML, like Gecko) Version/3.0.4 Safari/523.10
Accept-Encoding: gzip
Accept-Charset: ISO-8859-1,UTF-8;q=0.7,*;q=0.7
Cache-Control: no-cache
Accept-Language: de,en;q=0.7,en-us;q=0.3
Referer: http://web-sniffer.net/
Here is the RFC:
http://www.w3.org/Protocols/HTTP/HTRQ_Headers.html
