Hey, so im just getting a line accross the center of my monitor. I can see the game playing on this very tiny line. Is there something i can tweek to get it working or does it need a cap kit?
Often times, when you only get a line across the screen, it's just a bad solder joint. You don't say wether it's a horizontal line or a vertical line (although, it's usually horizontal). Check the solder joints on the yoke connector. You can also try wiggling the yoke connector while the monitor is on, to see if it changes the picture.
