DarkSide
Hi.
I had the last few years a Data East Jurassic Park machine standing in the garage in pretty "bad" shape.
Put a question on RGP if i should part it out, or restore it, well the decision was to restore it, and i've got the machine moved inside, and started taking it apart to clean.
As of writing this the project is going ahead, a lot of new parts have been bought, and most of it is on way.
The biggest parts, or should i say most expensive parts missing was a Flipper pcb, DMD, and the DMD Controller, they should be here sometime next week.
But i do have a few problems with the machine, first is none of the flashers work, second is none of the special coils works, all the fuse holders on the PCB's has been changed to new, and correct fuses has been put in, door contact is closed when trying the machine, pop bumpers, slingshots, and a few other coils work perfect.
The coils are checked with my dmm, and found in good shape.
The coils that do not work are in the Bunker, Power Shed, and the coil that kicks the ball up to be fired out, im sorry i don't know the right name for that.
Any suggestions on where to start ?
