GuidoTorpedo
Pickup only. Or, I'll be at the Downingtown auction and can deliver it there with prepayment. Here is the deal with this, as far as I can see:
-Playfield is nice, usual wear by the scoops
-Translite decent
-Display/speaker panel is cracked, useable, but should be replaced
-Display untested, can't get game to boot
-No topper (do they ever have this)?
-Includes new chip set uninstalled from John Wart
-Coin door will need to be rewired as the plug was cut off
-Boards are all there, no acid on the MPU, someone did a crap job repairing a fuse holder on the power supply, they look ok otherwise
-game only boots to GI, no logic (might be the fuse issue on the PSB, as the hack is at one of the logic fuses)
-Game appears mostly complete. From what I can see, it is missing the coil for the ball trough. It might be missing more, but this was all I could tell.
-The gearbox that moves dino left to right is disassembled, and will probably need to be replaced
-Legs are not correct and look like shit
-Cabinet is below average needing some touchups on the head, mostly in the black, so not too bad. No water damage.
-The bottom of the playfield needs to be reassembled some, including the undertrough, trough kicker assembly, Dino left/right gearbox, flashers, and relay board, maybe more
Anyway, that's about it. The game is kind of a hot mess, but priced right for a DMD project with a good playfield to work with. Looking for $875, that's about what I have into it, so the price is kind of firm. I can also get it to York PA. Shoot me a PM if interested.
Thanks!
-Mike
-Translite decent
Thanks!
-Mike
