Jurassic Park: Lost World Jamma Board Compatibility
jeamoirleb
Ladera Ranch, California
Hi there, I have a Jurassic Park: Lost World Vertical Stand-up cabinet. Does anyone know what other games are compatible with this set-up and if its easy to change over?
If you have the Sega game, there aren't many compatible games due to the gun setup on them. Confidential mission, House of the dead two and Maze of the kings all use the same gun setup as your game. I don't know if they are plug and play in your cabinet.
Ive tried and its a major hassle to get it to work but its not really worth it considering the modifications that would have to be made.
Thanks Guys
Thanks - Im also not an expert so if i was to convert this cabinet it looks like it would have to be a full overhaul which is unlikely to happen due to cost and it would be a shame to ruin it as it is a home use only and real fun game thats in great condition. If anyone else has any further advice it would be appreciated. THXS
Sadly, the Lost World was the only traditional gun game on the Model 3 platform. The other two shooters are LA Machineguns and the Ocean Hunter. Those games will plug right in, but they use a gun setup which relies on two potentiometers (per gun) to locate the shots.
As stated, you could use the Type 2 gun setup from Lost World with later Naomi and Chihiro gun games, but none of your wiring will work with the newer platforms, and those games require a high res monitor.
So, no, there is no easy drop in conversion.
SW trilogy -> lost world?
Does this infer that a model 3 system with joystick (ala Star Wars Trilogy) could be converted into an Ocean Hunter (using joystick for crosshair aim) fairly easily? But converting SW Trilogy to a Lost World may be more difficult?
