Jungle Lord - power board pinout -Need help
kfuller19
Permanently Banned
Donor 4 years: 2012-2015
auburn, Georgia
Hello all...thanks for your time. I have a hacked up jungle lord Williams pinball....
Have it pretty much put back together but one of the connectors were ( Re engineered ) :)
anyways i need help with rebuilding the connector if anyone has this game a picture of at least the colors of the wires would be great!
heres a picture
now i have these wires to rebuild the connector
4 white - yellow stripe
3 yellow -
1 purple
if anyone knows the order that would be great!
thanks
Thanks for checking
I'm thinking it dosnt matter which wire goes where as long as I group them
The yellow together and the other four together
Anyone with a jungle lord confirm this?
I don't have a Jungle Lord but it has this information in the manual: http://mirror2.ipdb.org/files/1338/Williams_1981_Jungle_Lord_Manual.pdf
On page 26, its connector 3P8 on the power supply (towards the bottom of the page). The numbers in the middle are the pins on header 3p8. In your pic, pin 1 is on the right.
From your pic the order should be:
White/yellow, white/yellow,White, White/yellow, KEY, Yellow, Yellow, Violet, Yellow
Double check your wire colors, one should be only white with no stripe.
This header is for the GI and usually gets toasted along with the pins. Make sure you are replacing the header on the board too because it is burned and use Trifurcon pins.
MAN thanks a lot... i must of looked over it a ton of times cause i swear i looked through the manual 20 times.
ANYWAYS huge THANKS!
