scamp
Has anyone rigged a Taito Jungle King/Hunt for free play using the Bob Roberts method of connecting the coin mech switch to the player 2 button?
I know he says it works for 95% of games, could JK be part of the 5%?
I cannot get it to work...either nothing happens or it starts firing off credits as soon as I turn on the machine!
I basically took a piece of wire and made it have 2 ends on both ends of the wire...I put a male and female wire connector on each of the ends so that one end of the wire had a male and female coming off and the other end did the same...I then removed one of the connectors from the coin switch and connected my wire in its place with the female and them put the male end of my wire into the removed wire....I did the same on the player 2 button...basically no harness wires were cut and I used the existing connectors...Anyway it didn't work...
I really want to rig this for freeplay without adding an additional button in the coin door or something...and there is no freeplay chip out there...
Any ideas would be appreciated!! Thanks!
-S
-S
