Jungle Hunt/King marquee dimensions
gobsgraham
AB, Canada
I have foudn on other threads that the dimensions on this are around 6 1/2" by 22 3/4" for the overall size but can someone tell me the visible sizeof the glass/plexi. I want to get a marquee made up from GameON That is the full size but with all images fitting into the visible part and just black under the metal brackets. I can measure mine when i get home but would like to order today if I can.
Just measured my ZK marquee, which I assume would be the same size as JH
visible dimensions are 144mm X 579mm .....you can convert to imperial using online conversion calculator.
john
