Jump Bug Question
flynn54321
GREEN BAY, Wisconsin
Does anyone know where the speaker + and speaker - pins are for a Jump Bug?
It appears there are 2 different version of the board and 18 pin and 22 pin.
My board is the 22 pin... I cant find a pinout that shows the sp + and sp - for my board.
Can anyone help?
sound
pin 18 is sound out and then use pin 21 for speaker common.
cool game!
So I am facing this issue right now with my jump bug. When making a Jamma adapter, does speaker + go to 18 and Speaker - to 21 (or ground)?
If your board is the 22 pin, then yes, according to the above. Speaker+(audio signal) to pin 18, Speaker- to pin 21(Ground).
I'm not sure what is up, but I still can't get sound. I have a Jamma adapter, and according to it, pin 21 is going to ground on the Jamma side and V is going to speaker + on the Jamma side. Still no sound. Does something need to be hooked to speaker - of the Jamma side?
OK, I got my sound working, and to cut down on confusion, Pin 18 is Speaker + and Pin 21 is Speaker -. Most online pinouts leave the sound out of the diagram completely, or mention 'audio out' and 'common ground' for those 2 pins. No idea why it was so difficult for someone to just type: Pin 18 is Speaker + and Pin 21 is Speaker -. Cuz that's what it is. Hope this saves someone some hassle down the line.
Here is the updated pinout:
Updated from this http://www.arcade-museum.com/pinouts-game/8250.html
Code:
[FONT="Fixedsys"]
Jump Bug, Sega (G-04-JB) <-- Not sure why this says Sega, this is the Rockola version. The game was made originally by SNK.  Did Sega distribute in Japan?
       Parts Side      |      Solder Side
              GND  | A | 1 |  GND
              GND  | B | 2 |  GND
              +5V  | C | 3 |  +5V
              +5V  | D | 4 |  +5V
                   | E | 5 |
              +5V  | F | 6 |
          2P.Down  | H | 7 |
          Coin 1   | J | 8 |  2P.Up
          1P.Down  | K | 9 |  1P.Up
         1P.Start  | L | 10|  2P.Start
          1.PLeft  | M | 11|  1P.Right
          1P.Fire  | N | 12|  2P.Fire
          2P.Left  | P | 13|  2P.Right
        Table GND  | R | 14|  Coin 2
                   | S | 15|
              Red  | T | 16|  Green
             Blue  | U | 17|  Sync
                   | V | 18| Speaker +
             +12V  | W | 19|  +12V
             +12V  | X | 20|  +12V
              GND  | Y | 21|  GND (Speaker -)
              GND  | Z | 22|  GND
[/FONT]
DON'T USE THIS ONE!! It is completely wrong:
http://www.crazykong.com/pins/Jumpbug.pin.txt
The video pins are reversed etc.
How do we go about editing the KLOV pinout???
