Hi,
I have a jumbo skill crane board set (3 seperate boards) that will not run the "credit/timer" display. When the display ribbon cable is connected to the cpu, the crane will not coin up and the display does not come up. The crane cannot be played with the cable connected. When the display ribbon cable is disconnected the machine will coin up and you can play ONE credit at a time. I can see it coin up by watching the coin counter, but it won't coin up past ONE play. The claw is still timed during play, you just can't see the countdown. Also, the coin door lights turn off when you coin up and turns on when the play is done.
I have tried another display and cable with the same result. The power supply is working. The crane works great besides the display issue. Any suggestions?
