JROK Williams Multigame Bubbles Reset
FrizzleFried
NAMPA, Idaho
I was playing Bubbles last night on my JROK Williams Multigame when all of a sudden I get a reset... a full reset of just Bubbles, including the "carpet" screen at the beginning.
It didn't reset back to the menu... it just reset Bubbles as if I turned off then on Bubbles.
Known bug in the Bubbles code?
Interesting, Frizz. I don't have an answer for you but I had a Bubbles issue on my JRok multi too. It played fine for a few weeks and then all of a sudden I can't get a game to start. It shows me the attract screen but I can't actually start a game. All of the other games are fine, just Bubbles does this. I don't have it wired to the coin door so I haven't had a chance to see if credits can be added, but it's not in freeplay any more. Is there a setting for that somewhere?
Known bug on an original dedicated Bubbles.
Sounds like it lost settings (!) You'll have to go into Bubbles put the game in test mode, using the JAMMA test switch then step through the options using the JAMMA service-switch until you get to the settings menu and re-enable freeplay.
- James
