tbullet
So to answer, no. You have to pull 12 or 30 volts from the PS, it needs to be fused, and you connect the knocker to the coin counter 2 on the board, aka "H"
do not take voltage from the board to power the knocker and make sure you have a diode present on the knocker.
I might have misunderstood what you meant about powering the board, but it is a standard jamma pinout.
I have a 12 volt knocker fused with 1 amp already with a diode. I'll add a pin to connection H for the coin counter 2. Just wanted to make sure on that.
As for powering the board. Page 4 of the manual states I only need 5v DC 400 mA. On the jamma connector, pin C & D are both are 5 volts. I would only need to connect C or D on both sides of the connector or BOTH C&D on both sides of the connector to the power supply? If I only need 5 volts and a ground, I should be able to connect B & C to the power supply to get my 5 volts correct?
Thanks what I'm asking. connect A & B for the ground, Just C for 5 volts or C & D for the 5 volts for power.
thanks.
