JROK Multi-Williams wiring and questions - please help.
blkdog7
Massachusetts
--- EDIT ----
I figured it out! There is nothing to see here, move on.The manual sucks! Great board, though. It doesn't cover the MULTI-WMS settings at ALL and assumes you are using a JAMMA harness with 4 buttons which is not standard.
First off, sorry if I sound like an idiot here, but this is just not making sense to me. SORRY!
I am using the MULTI-WMS setting in the MENU and not STANDARD. I have a JAMMA harness with 3 buttons per player. I have JROK's manual for this thing. I also have Clay manual that shows supposedly how the wiring should go in a JAMMA cab (I guess he followed Clay's wiring scheme.) But, it doesn't work. According to Clay's wiring two wires go to both the left flap AND the reverse button (which is the SAME button). That's fine and all but now I have one button with no wire! 6 buttons, 6 wires, shouldn't each button get a wire? It works fine in Joust but when I go to play Defender the Reverse button also does Hyperspace which makes no sense according to the documentation.
Anyways, I can't get it to work right. My buttons are all messed up and I am at a loss.
I have a JAMMA cab with a Multi Williams Control Panel. Two 8 way joysticks and 6 buttons plus 1p and 2p start.
Please tell me where each wire from the JAMMA harness should go on the CP so it works with all games. Cause it's not making sense at all.
So, where do the following go and to which button?:
P1 button 1
P1 button 2
P1 button 3
P2 button 1
P2 button 2
P3 button 3
Do I need the additional buttons header? Or, is that only needed in a Williams cabinet conversion not using a JAMMA harness? And if I do need the header, that only adds buttons 5 and 6. What about P1 button 4? Where does that come from!? Arrgh!
This is the CP layout I have:
