jrok multi-Williams control issues
savit4l8r
Riverside, California
I have a jrok multi-Williams and the games all work fine EXCEPT for the player 1 joystick on Joust. It will not move left or right, you can only flap. The joystick works perfectly fine for every other game on the board, just the issue with P1 on Joust. Any ideas? A board issue? Something else? Thanks!
Ok, now that's just weird.. try going into the Joust test mode and see if in control test it can see the left-right on the stick. Then also reset setting back to factory defaults.
- James
