Jrok Joust side by side image....
kags1969
Sunset Valley, Texas
Just got a new JROK Board for my dead Joust cab and have a split image... i am running adjustment pin from the jamma harness to the horizontal pin on the chasis... any ideas? Thanks, Kags
ok, well i hooked up the vsyc and hsyc to the jrok board and no changes... I also went out to radio shack and got a horizontal width adjustment tool and did not see a large change...
The Chasis shows the following for the pins
1 red
2 green
3 blue
4 ground
5 v sync +
6 H sync +
7 grd
8 Vsync -
9 H sync -
I am wired to 1 - 6 as indicated. I tried moving ground with no changes....
1 red
2 green
3 blue
4 ground
5 v sync +
6 H sync +
7 grd
8 Vsync -
9 H sync -
Using the numbering that you have here you want to hook it up as...
1 R
2 G
3 B
4 Ground
5 NC
6 NC
7 NC
8 NC
9 Sync from pin "P" of the Jamma harness.
The VGA mode jumper in in the upper (enable) position, it should be in the lower position for a normal monitor.
- James
