racer2e
Since the Jrok board does not have a vga connector, did you guys just cut the end off your monitor cable or did you solder a vga connector on your jamma harness? How do I wire in the vga monitor? Does anyone have a pinout showing what Jamma wires go to what pins on a 15 pin vga connector? I assume I need to use the posative and negative sync?
Thanks, Jayme
Thanks, Jayme
