JPLW egg and snagger just stopped working
AUSyTyIN
Littleton, Colorado
They don't even try. I had the glass off yesterday cleaning the play filed and checking switches and lights. I was trying to get the motor up/down switches to engage, so I manually moved the snagger (after dropping the drop target). The switch never came off the up position. I put it back, and continued cleaning. I put everything back together, and the snagger wasn't working (but the egg was). I played a few games, then unplugged it and let it sit over night. I went to play it today, and now the egg isn't opening either.
The motors/actuators don't even try to work for either of them. I've never been able to get the snagger test to work, even when it was working fine. I've done a factory reset, but that didn't do anything. Can anyone help?
Update: I just went and messed with it some more, and I realized that none of the strobes are working. I performed a coil test, and only 1/2 of them are firing. Does anyone know if there are two different fuses for the coils, and where they are? I've only found 2 by the tilt plumb, and 3 on the underside of the PF...
