Jpac w 25" Hanatrex installation HELP!
ok if i set it to 640x480 it would work fine but shaky like 3.0 earthquake.. if i change to 320x240. shake would stop and show perfect picture.
advise?
replace montior to trisync? or just arcade vga 3000 will fixes that .. what i have is.. arcadevga HD2400.
LMK thanks
Any chance of a video of what your describing?
Since you're using a standard res monitor, 640x480 is outside the usable resolution. If you want those higher resolutions, then you would need a tri-sync, but they are pretty pricey. What kind of games do you plan on emulating? 90% of the arcade games out there are standard res. The other 10% either can't be emulated or don't work well under emulation. I'd say just stick with the standard resolution. Tri-sync is only worth it if you plan on running real high-res games (Naomi, Atomiswave) and standard res games.
ok here s the deal.
i decide and finally figure things out. i set window resolution to 640x240 and it shows fine. im leaving it be.
i opened maximus and set 680x480 and shake stopped. everything looks good now..
i guess that works for now..
now i have to focus with joystick hooking up with jpac using winipac and goes on!!!
thanks for the feedbacks.
yes.. im glad it works now..
new issue:
everything hooked up.. ps2 cable from jpac ps2 keyboard to motherboard ps2 keyboard
It powers up jpac just fine. sync everything s perfect except one thing.
I installed winipac and clicked options to first part "jpac" and hit program. It searches then kept getting "Timeout" WHY?????
i had tried everything and it s useless.
is it because of this .. i need to hook up another ps2 cable from jpac mouse to motherboard mouse also? or it s not the reason??? LMk and i ll go store and get another one male to male ps2 cable.
LMk thanks..
Glad you got it working.
