devillocke
So, the Bart joystick on my simpsons game is worn out. I'll probably still end up replacing it, but this was free, and got me going. This worked out better than I expected, as it now plays as good as the others on the system. But, when I took apart the joystick, I found the rubber was separating on three of the four sides. I had a spool of upholstery thread, and sewed around the outside pulling the rubber back together. Before I reassembled it, I took a picture to share with you guys.
I imagine I could make it last even longer if I switch it with the one from the Marge joystick...
