Hello, I have a Namco classics 2 machine with unresponsive joysticks. The joysticks work when you are going side to side. However when you need to make a quick turn it won't work. For example when pac-man is going from left to right and he needs to avoid a ghost by turning and going either up or down the screen, you need to slam the joystick up more than once to get a response.
I checked the connections on it and I don't see anything wrong. I also swapped one of the joysticks and it didn't make any difference. When I put the game into test mode it registers all of the movements you make with the joysticks, and it seems like they work perfectly. Then you go to play the game and you lose in the first 15 seconds because the joystick doesn't work. The machine is on site at my friends store, and people are complaining about it all the time. I hope someone knows what could be wrong. -thanks
