Joystick base size help
bongoben
Wisconsin
Hey, so I am in the midst of putting together a 48-1 for my father. The CP previously had an Arkanoid spinner in it which has bolt holes at the same points as a Nintendo joystick base but on the joystick I was planning on using (a Ms Pac Reunion stick) the base is about a half inch too short in comparison to the bolt holes. Has anyone used any sort of mounting plate in this situation? Anyone have dimensions of the ones on Bob's site? Or should I just use a Nintendo stick?
Have you checked mikesarcade.com ? He has some adapter plates but I am not sure he has the one you need but worth checking..
It could be this one http://www.mikesarcade.com/cgi-bin/store.pl?sku=NJOYA It converts a standard to a nintendo.
Dave
