Dokert
How much is a rebuilt power supply? What is the guys name in Central Texas who rebuilds them?
Ken
YellowDog
The post above yours asking this info.
Another option to consider is upgrading your power supply to a Jamma style power supply.
I am currently restoring a Robotron and I plan to use a Jamma power supply (higher reliability).
PM me if you need more info.....
Regards and Happy NEW YEAR!!!
What is your +5VDC reading.
Here's a snippet from the manual.
+5v DC ADJUSTMENT (R10 & R24)
Before adjusting the voltage output, always check the output at the supply for AC hum. This hum should never rise above 0.005v on the +5v DC supply.
This is measured with the AC setting on your Meter.
If it does, consult your schematic drawing set for proper DC voltages throughout the circuit. Test for these with the DC setting of your multimeter.
Make a second check using the AC setting. Pay particular attention to readings at TP5 (top of capacitor C10). If the voltage here is too low (less than +11v DC) or you
find excessive ripple (more than 700mv rms), replace the capacitor.
There are instructions on how to decrease, or increase voltage on page 7 of the instruction manual. It's really quite easy. I'm interested in what the +5VDC is, and what the AC ripple is.
There isn't an adjustment pot on either Defender or the later Williams PS boards, unless somebody hacked one in. The "official" way to adjust the power supply is to make minor modifications to the resistor network comprising the feedback part of the voltage regulator circuit. This normally involves removing R10 to slightly increase the voltage or adding a larger value resistor to replace one of the other resistor (can't think which one right now. It is documented in the schematics.).
ken
i read a post from someone here saying that he had about 4.8 and adjusted to 5.1 and all was good! he obviously has a switcher then i guess. i didn't know where to ck 5v so i assume mine has low voltage also!
i'll try removing R10(nothing goes in its place?) on power supply pcb then and see if it works cause like you guys said, i want to keep original without all the switcher probs!!!
ahh...ok! i have a Joust that will not let you put in 1st player initials but will 2nd player. i read a post from someone here saying that he had about 4.8 and adjusted to 5.1 and all was good! he obviously has a switcher then i guess. i didn't know where to ck 5v so i assume mine has low voltage also!
Check the voltage with a DMM before you mess with it. Check the voltage at the ps board and then again at the CPU board, best place is to test at the RAM. It is likely that you are losing voltage over the connectors and the wiring. I have seen several cases where the ps board is putting out 5.0V and the CPU board is seeing 4.7V because of corrosion on the connectors.
If the voltage on the board is lower than 4.9V then it is probably worth spending the money to get it rebuilt. That usually means that the caps are starting to dry out or the voltage regulators are starting to drift. THis can happen even if the 3 LEDs are lit. They are a good warning sign that the PS needs help, but they are not fool proof.
ken
Defender style ps is a 5k pot at R2.
Joust style ps is a 5k pot at R25.
so how is that done with a wiper on the pot(3 pin pot)? can you explain or is there a 2 pin pot that i'm not aware of?
i will do this for adj also!!!
thanks
thanks
I use these and cut a leg off.
dumb question but i would cut off the left or rt cause the wiper is the center, correct?
oh and i do only get 4.87 on ram but didn't have manual to see what test point to read on power supply!
Yep, left or right at your choosing.
Pin 15 of 4J2 (Pin 2 Key)
