olePigeon
Hello,
I was troubleshooting my Joust and was going to check the voltages, but my Joust doesn't match the only manuals I can find online. Not only is the power supply different, but so is the harness to the various boards (my Joust ROM board only has one 5v line, whereas the manual indicates two.) It's working fine, but I wanted to recap it anyway for preventative maintenance. Is there an alternate manual?
Also, there's a ticking noise coming from the CRT, almost like the sound of a watch. I'm assuming it's arching a tiny bit? I watched a CRT repair video on YouTube, but I wanted to confirm the safety of their tip before proceeding. The person said that putting a little silicone grease on the anode sucker will help create a better seal; I'm thinking that might help with the arching. I do have a CRT discharge tool, so I'm confident I can do this safely.
As a side note, I did successfully diagnose my Joust. It'd seemingly randomly stop working when moved. I thought maybe it was a cold solder joint, but upon a tip I learned here, I pressed lightly on the ribbon cables and observed the error codes. They would change as I pressed on the cable between the ROM board and RAM board. Upon closer inspection, the strain relief was broken and some of the wires were loose. So I need to pick up a new cable.
