JOUST II OWNERS (need your help)
jetusenet
Donor 4 years: 2011, 2013-2014, 2024
Staten Island, New York
Hi;
I am working on a project and need verification of the following ICs'. They are all located on the Video PCB of the Joust II boardset.
The PROMs that I need verified on the Video PCB:
IC14 - A-5282-10295
IC47 - A-5282-10294
IC60 - A-5282-10292
If you have the time, would you please check to see if the part numbers listed above are the same as the ones on your Joust II video PCB??
Also, if someone has a manual with a wiring diagram or schem, I would be in your debt. I already have a manual but it does not contain the wiring etc.
Thank you very much for your help in my never ending projects.....
Jeff
Hi;
To date, I have received confirmation that IC60 and IC14 are the same on the Turkey Shoot and Joust II video PCBs, still waiting on confirmation for IC47.
Jeff
OK, it appears that TS, MM and Joust II all have the same PROMs on the video PCB, which would make sense as they all share the same video and CPU PCBs.!!
Still need confirmation of the part number of the PROM located at IC47 on the Joust II video PCB.
Jeff
