Joust back door harness screws
WadeLanham
Charleston, West Virginia
What is the correct length of the screws in the Joust back door that hold the white plastic harness loops, and the metal pcb plate?
Mine seem a little too long and bulge through the backdoor slightly when tightened up. I don't think I had any shorter screws elsewhere on this game… maybe…
Is this normal, or did I get a few screws swapped at some point? I think they're about 3/4" long.
What is the correct length of the screws in the Joust back door that hold the white plastic harness loops? Mine seem a little too long and bulge through the backdoor slightly when tightened up. I don't think I had any shorter screws elsewhere on this game.
It's probably normal. But I always get the 5/8" long ones that way I don't worry about 3/4" inch material. I do believe that Williams's back doors are thinner than 3/4" material though. So it wouldn't hurt to just get half inchers and be safe.
It's been a while, so I can't quite remember but I think I had shorter screws for the metal tabs for the latches. I need to remove them and see. I still can't figure out how I ended up with too many long screws. Yes, the back door is thinner, around 1/2".
