Journey Joystick issues part 3
noice87
Glenn Heights, Texas
I replaced the switch I though was bad and still had the same problem. I looked over my wires and had wired from the wire harness to the conector 1up to ground and ground to 1up which was causing the problems. When I rewired that that fixed that problem.
Now the problem is when I took off the shaft I lost a spring. Any idea where to get a replacement?
Other than a couple minor wiring and cleaning up the CP wiring the spring is my last obsticle.
Thanks Steven
