pseeds
I have a JNAH cabinet with wiring but no PCB/drive/power supplie(s). I recently acquired a PCB, HD, guns and all wiring (apparently) as a used kit. I have begun installing the parts and now have a question about the second power supply (for the guns). The cabinet I have splits the 110 and FG so it does appear it had two power supplies. This is the PS for the guns -
https://www.icegame.com/teamcenter/plugins/sitecontent/media//AH2012.jpg ( I do no currently have this PS). I was assuming this PS was only needed for a recoil type gun(?), which I don't have. I have the standard .45 guns like this -
http://www.happ.com/amusement/optical/96210017.htm but without the black tip.
I think I can use the set up I have and do not need the secondary PS as the guns optical interface are driven by the game PS. I will just secure/remove the secondary 110 wiring that was for the gun PS (as above) so it won't cause a problem. Sound reasonable?
Also, both of the harnesses I have (see here - https://www.icegame.com/teamcenter/plugins/sitecontent/media//AH2054KX.jpg) do not have the little male extensions (top right of pic). I found an 8-pin connection that I think will work.
If anyone has any advice/experience with this game, I am open to it.
TIA
TIA
