Johnny Mnemonic Hand Adjustment Help
Zack5959
Indiana
I started playing this game at Christmas, and the hand always sounded bad moving front to back. A few days later it failed the self test and the computer deleted it from gameplay.
Turned out to be a broken wire so I repaired that. Also, I cleaned the track/screw and re-lubed it and it worked great for a day.
Yesterday it stopped working again and failed the self test.
I looked through my manual and found some coordinates as to where the hand is supposed to be, but it doesnt have enough travel to achieve the Y Coordinate. Furthermore, im confused about the boxes next to the x and y on the screen.....they can be checked or unchecked depending on where the glove is. But, I dont know if a checked box is good or bad.
Anyone have any experience with this?
there are microswitches that close - if I remember well they're on both sides of each axl to detect if the hand is on the very beginning or very end.
when these switches close you see an X in a box
check if the metal blade of the microswitches closes well when the hand moves against/over it
