My Williams pin has a non firing right Jet Bumper. I ran through the selonoid test, and it isnt firing off. Can someone guide me through fixing/troubleshooting this? I'm new to pins.
If it doesn't fire in test, I'd carefully go over the wiring at the coil. Especially the tiny wires coming off the coil to the coil lugs. Dig around them, easy to have a break or poor solder joint that is hard to see.
LTG
Manually ground the metal tab of the driver transistor that drives that coil. If the coil works then it's a problem on the driver side. If it doesn't then you know it's a problem with the connection between the driver transistor and the coil, the coil itself, or the positive side coming to the coil from the power supply.
