Jerry riggin'
bottlejunkie
Donor 2011, 2015
houston, Texas
what are some "methods" you have used to make something work on a game?
I have mentioned this before, but I used blue cellophane from Hobby Lobby for an over lay on my Asteroids Deluxe because I couldn't source a gel at the time.
I had a Pop-a-Ball game that was old school and used redemption tickets, I couldn't figure out how to override the ticket thing so I found some tickets in the bottom and cut a slot under where they came out and used clear packing tape and taped about 10 of them together to form a loop so it would just keep counting tickets and played great, it looked similar to this one.
what have you done that wasn't really up to spec?
I've done the exact same thing with tickets on a machine that owed thousands but seemingly didn't have an easy way to clear them. I taped up a loop and walked away for an hour.
I've done my fair share of non-factory fixes, but probably the most creative one was replacing the speakers in a Crazy Taxi with a small radio.
The game is on a route nearly two hours away and had already given me a bunch of trouble, this was my third visit there working on it.
I finally fixed everything else only to have the sound drop out. Thankfully the Naomi spits out sound over a couple RCA connectors. I went to the neighboring discount store and bought a little radio with a 3.5mm jack and an adapter and it worked great.
A previous tech tried to make a 1/4" potentiometer fit with a 6mm gear by grinding it smaller. That didn't work. I tried to salvage the pot by grinding it even smaller and sleeving it with a 6mm OD piece of brass tube and JB weld. The problem is it wasn't perfectly on center so it wouldn't engage the gears properly. Still useful for a volume control or something similar.
My favorite was "fixing" bad fuse clips with binder clips. For those who don't know, data east pinball power supplies have fuse clips that always break. For reference, I didn't do this one.
I had a Boot Hill that came with the background plastic broken into several pieces, I used fiberglass matting like that used on cars and boats but instead of the resin (which doesn't stick to plastic) I used plastic epoxy and it seem to make a pretty rugged repair and hid pretty well if done from behind with the pieces lined up good.
