Jamma to MVS cab adapter from jammabords.com -5 connect hole?!
Ok, Im probably going to get my machine fired up today. Hoping to remove the switch and get it back in place. i have NOT yet put the -5 volt line in. I can not see the traces to verify that 4 slot neo board does NOT have any leads coming off the -5 volt connector yet.
I am slightly confused though.
I notice the -5 volt trace on the Jamma boards adapter Has a hole about half way between. It does look like -5 would flow around whats marked the -5v connect. but it also looks like the trace is very minimal??
Do I have to solder in the connection here?. or is it a optional solder if you dont want to run the -5 perm ??..
im a lil lost on this and they did not include any documentation to explain this part..
Im going to check out their website and see if I can figure this out, but I would like to see if any of you have used this hole or just ignored it?. any performance change from filling it with solder or just leaving it?
thanks everyone
Link to image from Jamma boards.
http://www.jammaboards.com/store/images/uploads/JAMMA2MVS/JAMMA2MVS_Adapter_640x292_LR.jpg
Can see it on there, but not much mention of it there..
thanks everyone
