Hi folks.
I currently have a Gauntlet Legends game; 4 player; Jamma+; 3 buttons and 1 49-way joystick per player; 4 players; new tri-res 27" monitor.
I'd like to add an NBA Jam boardset to to the game. NBA Jam is also Jamma+; 3 buttons and 1 8-way joystick per player; std res 25" monitor.
So if I were to add the NBA Jam boards, set the dip switch on GL to use 8 way sticks; replace my 49-way sticks with 8 ways; could I then simply swap the Jamma cables from the GL to the NBA Jam when I wanted to switch games?
Is it that simple? Both are Jamma+ games; are they swappable? What other things (if any) would need to be swapped if I were to swap the Jamma+ cables to switch between games?
Thoughts? Opinions?
Thanks in advance!
edit: I'm particularly concerned with the player 3 and 4 controls because these don't appear to be part of the Jamma standard
Thoughts? Opinions?
Thanks in advance!
