Ok, still learning stuff here. With a JAMMA cabinet, should I take all the grounds to the ground of the Power Supply?
I noticed the coin slots have a ground going just to a screw attached to a big metal piece. Should I move that down to the ground on the power supply? What is the standard practice for grounding these items?
JAMMA harness - Attached to power supply ground? (Most connections are just daisy chained together. I think I read that was normal.)
Coin slots - Currently just attached a metal plate? Is this right?
marquee light - Think that has a ground attached to the power supply ground?
