JAMMA Drivers...
FrizzleFried
NAMPA, Idaho
I was playing 1000 MILE RALLY last night and it got me wondering... what other JAMMA drivers are there out there that would/could be dropped in to this cabinet? It has a 360 degree wheel and a microswitch accelerator pedal. It wouldn't be too difficult to add a HIGH/LOW shifter if necessary.
Friz,
I think you can play Final Lap series in that same machine and maybe Double Axle ?!?!?
I have a NOS High Low shifter (with button) if you need it.
This one:
Hit me up via PM if you need it.
Steve
MM
What type of cabintent do you have?
What controls?
From KLOV, there are a number of configurations...
If I had a good sit down, I'd put either an Xbox or Dreamcast inside.
well, there's great 1000 mile rally 2. Not sure if Final Lap will drop in or not - i'm thinking that 1000 mile rally has a seperate header that the steering plugs into, as well as the pedal and brake (if you have one). Seems that FL has a hard to find .100 edge connector on it as well. IIRC, neither are straight Jamma. You could do it, but you'd need to make an adapter to go between your steering/pedal hookup in the cab to make it interface with the other board.
I have both FL2, G1000MR, and G100MR2 (aka mille miglia) in one cab, fwiw run through a Parallel port to switch between the games. You can make it work, but it won't be as easy as regular jamma where you unplug one board and plug in another.
Yeah, it uses a separate header for the steering. I'm already on the look out for 1000 Mile Rally 2... this is what the cab looks like:
Friz,
Steve
MM
Anyone know of where to get just the Low/High overlay for the shifter? My shifter works great but the overlay is missing
Friz,
Steve
MM
Steve... i'll keep that in mind and will do if need be.
If you do...mind if I borrow it to see if it works then if you're interested in selling I may be interested.
Sorry, forgot about this thread. I don't want to sell it at this point, but you are welcome to try it out and see how it works with your cab.
