JAMMA coin counter wiring
Here's a picture of my board. I "inherited" it with the wires directly soldered onto the board connector. Unfortunately the connectors are in pretty bad connection, so unsoldering it and putting on a harness won't be an option.
What I did was connect +24V to Pin 20, as well as one of the coin counter wires.
The other wire from the coin counter I connected to Pin X.
The negative from the 24V PSU I connected to Pin 1 (GND).
Nothing happened (nothing fried either, thankfully).
Coin Counter on the Nintendo board is Pin20 to +24V & +Coin Counter, and PinX to -Coin Counter.
Installing the 24V ground to Pin1 is sharing ground between two power supplies. This can be (but isn't always) detrimental.
Here's the Coin Counter section of the schematics: (note that it goes to GND2, which is apparently shared)
attachment.php
attachment.php
Thank you, so as far as I can see I wired things correctly.
Apart from sharing GND with two PSUs there doesn't seem to be any other issue.
Yet, it's not working. The counter itself works fine, when I connect its wires directly to the 24V PSU.
Yes. That is correct if you have a 12 volt meter.
Hello sir, I realize this is an old thread and a few of these members seem to banned but I am wiring up my coin door now and have a question.
I understand the above diagram and how to hook up the counter properly but I want one counter to work for both of my coin slots. Do I connect the Counter 1 and counter 2 lines from the edge connector together and run it to the counter with one diode in line or would I need two diodes in separate lines? Thank you
The counter will work with both coin slots, as the coin switches are actually both wired to the same connection.
Pin 20 is counter, pin X is GND. There's no option to wire up two counters.
In your coin door, simply run the same wire between both coin switches. I think that's the way the original harness is set up as well, though it's possible that a separate wire from the other coin switch goes to Coin 2 on the edge connector, but I'm not certain. You don't need that though if you want coin drops to either slot register on the counter.
Sorry for the confusion, I am actually wiring up a Rygar PCB to JAMMA! I don't see a coin counter at all in the Rygar pinout so does that mean one won't work?
