What are the chances my new switcher was dead out of the box?
And im not getting any power to the PS which is brand new.
The switcher is getting 120acv to it.
What are the DC readings on its output terminals?
I feel like a complete idiot for this, my dmm battery was dying while I was troubleshooting and I think it was giving me false readings. The switcher is getting 120acv to it.
The switcher is getting proper voltage and no dc voltage out= New or not=BAD power supply.
Could be miswired. Some switchers are picky about line/neutral inputs being the right way around.
tomtime -- try swapping the L and N input wires on the switcher. You never know.
On the ac input of the switcher?
Yeah, there should be L/N/G. Switch L and N.
Huh? How exactly is this going to change anything?
If he's getting 120v at the input to the power supply, and nothing on the output, it's a bad power supply. Either that, or the power supply is in shutdown (outputs are shorted, etc). Live and neutral being swapped won't prevent the power supply from working.
-Ian
I can honestly say I've never heard of a power supply that cared. A reversed hot/neutral should NOT matter. Especially for a switcher. Incoming AC gets rectified straight off the bat. Reversed hot and neutral lines is a VERY common wiring problem in houses, not to mention all the games with the ground prongs broken off so they could be plugged into ungrounded outlets. I call BS on this. Find me an arcade switching power supply that gets fried (or won't function) when hot and neutral are swapped and I will be VERY surprised.As I said above, some cheap switchers are picky about how their input is wired -- they won't run or will fry themselves if you have line and neutral backwards,
Huh? It's AC. You can't measure it backwards.and I don't trust people to notice the minus sign on their meters, or get their probes the right way around for that matter.
