Jamma cab not powering on
pezley
Havant, Hampshire, United Kingdom
Morning guys, really hoping you can help !
My Total Carnage cab will not power on, when hitting that switch I get nothing, monitor, lights...anything.
Have swapped out the power supply switcher for a new one and still no joy. Have tried the plug and fuse.
I figured it might be the monitor initially but the coin door isnt even illuminating
Any suggestions would be amazing.
silly question(s)
is the backdoor of the game on it
if not have yoou pulled the interlok button out (when you place the backdoor on the game it usually comes into contact with a box with a little plunger). Depending on the game you may need to pull the plunger out. Not all games have one.
Start there and report back
Whilst the back is off now it was not initially when the issue started.
This plunger thing you talk of, I cannot see one on this cabinet.
At the back of the cabinet is a big device with what looks to be a coil and a 3 amp fuse. I have tried repacing this fuse but still no joy.
Rather new to all of this so thanks for the patience.
After stealing some of my fathers time he has tested multiple things and concluded it is the Isolation Transformer that is at fault.
Its a UK Spec cab, any one know where I could get this component ? or know of any that will suitably go in its place ?
what he is talking is the double acting interlock switch . Looks sort of like this
pull it out when you have the back off the game or coindoor in some cases , open
