Jamma board power wiring. Help needed please.
tbullet
Okanagan, BC, Canada
I have a Jrok multi-williams board and will soon need to apply power to it. I purchased a switching power supply which will provide the +12, +5 and -5 for the board.
It's a WEI-YA model WY-151C1.
I see it has 2 connectors at the bottom labeled AC/N and AC/L. Is this where I connect the AC power to?
I was told I need a EMI Filter. I was thinking of using one of these types.
So in regards to wiring from the wall outlet, I can go 3 prong grounded to the EMI filter, ground from the EMI filter to the earth ground on the switching power supply, and the 2 leads from the emi power supply to the 2 connectors at the bottom labeled AC/N and AC/L on the switching power supply. Correct?
I've never built one of these before and want to make sure I don't destroy anything in the process.
I can also use the earth ground on the switching power supply and connect that to my coin door as a ground correct?
Suggestions would be great.
Thanks.
Had a look and decided that this would work. Since I'm going to be running my lights from the 12 volt side and using led's, Do I need the isolation transformer since I won't be using that part of the circuit?
You will need the isolation transformer to power the monitor, unless you are using one of the new monitors that specifically does not require one. Most monitors do need an isolation transformer.
-Ian
I was going to plug my VGA monitor into a power bar that I was going to have in the cabinet as well. Could I plug the switching power supply into the power bar and bypass building this?
