Jamma blue elf 619-1 game goes to exit screen
Kcarcade
Florence, Kentucky
What's up guys need a little help. My bartop has the jamma blue elf 619 in 1 running inside it and it allows me to play the games but while playing the exit or continue screen pops up out of the blue. I try hitting continue and then it pops up immediately afterwards. I will mention that I was re running the wires and to get rid of the birds nest inside and I cut the wires for the track ball i dont know if this is the problem or not. I know that the 28 pin needs to be grounded which I have already done the cabinet was working perfect before I zip tied all the wires and consolidated everything, maybe a ground issue? any help would be much appreciated.
I would also look at tour P1/P2 start buttons since you hold that down to pull up the menu. Might have a flakey switch. Put it in test mode and bang on your buttons/control panel and see if anything (P1/P2 Start) shows connection.
