Jack in the Box Score Motor
expsp
Donor 2017
Pennsylvania
Having problems with the above machine. When one of the ten drop targets are hit (makes no difference which one) the score motor runs and doesn't stop (continues to increase the score) until the last target is hit. Any suggestion where to start to look for the problem? Thanks in advance.
On this game, do the targets reset when the bank is completed?
I am suspecting you have some sort of stuck switch and when it is resetting it obviously clears said stuck switch. However that would make more sense if only one target was doing it, not all of them. Interesting.
Good morning, OA. The targets do reset after the 10th is knocked down. At that point, the machine resets properly (awards the correct points & stops the runaway adding of points). Thanks.
