Ivan Stewart Off Road 3 Player Help Needed
NWIRyan
Donor 2012
Griffith, Indiana
I currently have an Ivan Stewart Off Road 3 Player game. I am experiencing an issue where the middle gas pedal does not reach full range unless the player on the left pedal is down also. I also am experiencing bleed through on the middle gas pedal when the left pedal is engaged. I get a 80 reading while in test mode on the player 2 readings when the left pedal is 250. When the Player 2 pedal is depressed alone, the max reading is 160. Any ideas? Thanks
check all wires going to and from the control panels. I would bet it is just a bad/dirty connection. Look for bent, broken, or pinched wires.
after that it's time to get your hands dirty a little bit and remove and exchange the two pedals between players, reconnect them and see if the issue moves to the other player or stays in the same position with a new/different pedal.
Double check your pedal wiring. I know there is a schematic for it somewhere. Most likely in the manual. I used it when I got mine because the pedals were wired wrong so I know it's there.
OK... Checked wiring and changed wiring to see if it was the specific pedal. It stays with the circuit regardless if which individual pedal is connected
