hold your test button/switch closed while you power up. Make sure and save after you make your changes, then shut it back off. Turn off or release the test switch when you power up again.
If you don't have a test switch wired up, turn on dip switch #4 while it's off, power up into test mode, make your changes, save, then shut it off and turn dip switch #4 off, and power back up...
