Up For Trade
Games Family Killer Edition 1315 in 1 p4 2.4 - New In Box, I have both the 1315 & 1940 hard drives.
New K7000 25' Flyback
6 K7000 Chassis - 3 x 19' & 3 x 25' NON WORKING
Polo 25' Monitor With Slight Burn - WILL TEST
Matsushita TM 202G 20 Inch Monitor - Non working but very clean tube & chassis. Fried something
9 AR2 Boards - But Need To ID - NON WORKING
Stargate Complete Board Set With Both Plates - Widget Board Needs Work
Stargate Full Repro Harness By Dokert with Revision
3 Williams Power Supplies - Stargate, Robotron, Joust Ect - NON WORKING
1 Williams Sound Board - NON WORKING
2 Williams Widget Boards - NON WORKING
1 Williams Heatsink
1 Williams Power Supply Board / With Heatsink - NON WORKING
1 Williams Main Board Plate
1 Williams Power Supply Plate
Pac 4n1 Main Board - Working
Ms. Pac Main Board - Working No Daughter Card Required
Pac Jr Main Board - Working
7 Ms. Pac Daughter Boards - ALL NEED WORK
SI Deluxe Plastic Moon Back Drop
Arch Rivals Cable Board
6 Pole Position 1, Two Board Sets - Non working
1 Mk 1 Main Board - Working
1 Mk 2 Main Board - Working
Arkanoid Board - Working
Arkanoid Spinner - With Circuit Board But Needs The Knob - Working
Mega Touch 5 - Needs Some Work Or For Parts
Tektronix 2335 Dual Channel 100 Mhz Scope
2 Tek P6120 10:1 Probes
2335 Manuel on CD
Data I/O 29A
UniPak - The First One
GangPak GPD - Ver 8.0
LogicPak 303A - Ver 04, Part# 950-007-004 D
303A-101 H&L Design Adapter
303A-100 Palasm Design Adapter
303A-001 Programming / Testing Adapter
303A-002 Programming / Testing Adapter
351A-070 Socket Adapter
Midway Full Size Project Cab
Items I Will Trade For
GO7 19' Monitor Frames
G07 Yokes
GO7 19' Chassis's
GO7 19' Capped Chassis's
4900's 19' Capped Chassis's
Midway Burgertime Bezel, CPO, Marquee & Stencil Set,
Ms. Pac CPO, Marquee & Vinyl Art
MultiWilliams Stargate Stencil Set
Robotron Shafts Used or Repro & CPO
[FONT=Verdana, Arial, Helvetica, sans-serif]VS Nintendo PPU RP2C04-0004[/FONT]
Missile Command Back Door
Pictures are not a problem just ask...
1 Williams Heatsink
2335 Manuel on CD
Data I/O 29A
G07 Yokes
GO7 19' Chassis's
