Dr. Morbis
Well I was playing my Bubble Bobble the other day, when all of a sudden the display got sucked into the middle of the screen and turned into a psychedelic Northern Lights kind of image, at which point I ran to the outlet and unplugged it. After a few minutes I plugged it back in to see if I'd get anything, and sure enough the monitor was dead but the game pcb started as normal and played blind. The monitor is a 25" Hantarex MTC 9110 with a fan mounted over the flyback (which didn't turn on when I plugged the game back in, so I don't know if the fan died first and something overheated or whether the fan is supposed to only turn on when the rest of the monitor is working properly...).
Anyway, my question for you experienced folk is: does this sound like a bad cap or something worse? With my limited knowledge and the research I've done, it sounds to me like it could be one of three problems...
-bad cap
-bad flyback
-bad HOT
Is this a common symptom that one of you can pinpoint? Do you think a cap kit will be enough or is there something else I'm missing?
Thanks in advance for your advice.
-bad cap
-bad flyback
-bad HOT
