Issues with ultimate mortal kombat 3
datn1zzle
Portnorris, New Jersey
I plug it in and everything works, game plays but I get no sound. Just a buzzing noise. I looked and looked online, but can not find anything. Please someone help me :) thanks guys!
I need to break out my meter. I don't have it on me. But what would I need to check I mean what pin? Just an FYI this is a street fighter 2 cab my mk1 works in there fine. I get sound and all.
You should have -5v then as that board uses it as well. A lot of the MK guys say that the boards are picky with voltage and need to be exactly +5v at the board.
Edit: Forgot to ask, are you getting any sound at all like at least humming or maybe static?
Okay I got it! I tried it out in my mk 2 dedicated can and it worked. I then looked at my mk 2 jamma harness and noticed the negative five volts. I looked at my other cab that it wasn't working in, and counted five pins in and it was an orange wire. Followed the orange wire it went to my power supply but wasn't plugged in. I plugged it into the -5 volts and voila it worked! Thank you so much for the tip on the -5 volts.
