Isolation transformers help
Buakaw
Donor 2017
Houston, Texas
Hi, anyone know how to identify the correct leads on an isolation transformer? This is inside a mk4 cab and it had no chassis which I'm trying to install now, but I'm not sure which leads to connect.
Update
I tested all the lines. The closest combination to 120 was 108v and 130v? I'm guessing it's bad and that's why the chassis was not in the cab when I got it?
I have a replacement ISO in a cab that does 130v even under load. I thought that was a flaw in the replacement ISO but 130v is still within the acceptable range for the monitor so I left it alone.
OP, I'd be curious if your does drop down a bit under load.
