masterfx
Getting a arcade monitor to replace LCD in cab and going to add a transformer. Question, I am going to use the AC outlet on the power supply but there are only 2 wires running to CRT. Do I ground to the neutral or earth ground?
IM using the outlet because the other wires are already being used. Here is the power supply. Happ 20 Amp
Thanks!
Thanks!
