Iso question
Djm
Had to put a hodge podge of parts together to make a power supply with iso transformer seems the output of iso is 119v tested this 19" monitor I have on a 109v from a different cab and work perfect only problem is I can't find anything online of this monitor/ chassis so don't know what it requires. Is it risky to run at 119v?
What monitor is it? If it's a 100 volt monitor you need that iso to lower the voltage like a Nintendo or some early sega transformer
